A repair manual should list everything that needs to be lubed.
oil is good, grease is better, but you need to disassemble pivot points for that. the chain lube finds it's way into where you want it without disassembly and will keep dirt and water out, just wipe off the excess over spray.
If you can get your hands on some Wurth Flexi Film that's the stuff, nothing better.
Goes on clear like WD40 but stays we're you put it and has great anti corrosion and lubricating properties.
Are you sure that's what it's called? A Google search brings up nothing!
really? chain lube seems a little sticky and also expensive. or am i just being picky?
