I have a set of integrated LED tail lights on an 03 636. Recently I discovered that the brake lights aren't coming on.
Both front and rear brake do not activate the tail brake light.
The day time lights are on, the turn signals both work.
Not a bulb problem, these are LEDs.
I checked fuses under the seat. All are OK
I checked wires and connections, nothing loose or shorting.
I jumped front brake lever connector with a wire. No effect.
I checked the pull mechanism on the foot brake to see if it was stuck in the on position. It was not stuck.
The brake light does not appear to be on all the time. The LEDs are usually much brighter when brake light activated.
It was working fine before, I didn't touch the lighting system at all.
After doing a bit of research, the only thing I can think of is that the relay thats added to slow the flashing down is somehow messed up. I didn't install this, it came with the bike when I bought it.
Somethings not adding up.
Anyone have any ideas or suggestions?
Thanks
Thanks
