boyoboy
http://www.clutchandchrome.com/news...y-yamaha-lead-to-rider-being-paralyzed-608252
what the fuk is yamaha doing?
Seems a little misleading; a snatchy throttle is one thing but "unintended acceleration" implies the throttle butterflies opening without any wrist input and the bike taking off.
I wonder how much experience Mr. De Lua-Ruiz had before hopping on the hooligan-esque FZ-09.
"Non-linear transition is a technical term for 'uncontrolled,'" Edwards said. "You give the bike some throttle and it could either glide you forward or explode under you, you can't count on the bike doing what you need it to do. It's a crap shoot that can kill you."
if you read the article yamaha acknowledged non linear throttle from CLOSED TO 1/4 THROTTLE. In first gear that would be more than a choppy throttle.
non linear means INSTANTLY.
I like pie.This is precisely where a pie chart would be of no use. Time to bust out the xy axis.
I like pie.
Maybe my comprehension needs some work, but this issue happens when moving at 18 - 37mph and riders experience jerkiness when they get back on the throttle between closed to 1/4 throttle thus creating the jerk.
Non-linear does not mean instantly - more just not at the same rate/degree as before.
Non-linear: designating or involving an equation whose terms are not of the first degree.
Another question to be asked is if the original owner of the bike was notified of this recall.
His lawyer said: "[FONT=&]In fact, a previous owner of the motorcycle had taken the bike into a Yamaha dealership in response to a 2014 recall involving headlamps, and the dealership did not advise him of the availability of the new software related to the throttle risk"
[/FONT]BUT, the recall notice was sent to dealers in Sept of 2014 (nearing the end of the year). Perhaps the previous owner fixed the headlight earlier in the year when the recall wasn't released?
Recall notices don't get sent out to subsequent buyers of the bike do they...?
The article poses more questions than answers and provide's only indirectly what Yamaha knew or did not.
Smoothing out throttle vs. bike exploding under you uncontrollably ... yeah, ok, almost the same thing, right??
No, it doesn't. In this context it simply means an incremental input delta to a control system results in more (or less) output delta than that produced by an input delta of equal magnitude applied elsewhere in the operating regime of the system.
Many cars nowadays have non-linear throttles that give a large amount of tip-in response just off-idle to give the illusion of more torque/power. Elsewhere in their operating regimes the throttle response is more muted and damped, often to give smoother performance during light cruise.
I think Yamaha's early FZ-09 efforts had ill-tuned throttle response maps that gave snatchy, jerky performance but the bike wasn't "dangerous" to the thousands and thousands that bought and reviewed it, just tedious and perhaps not for noobs.
Yamahas have always been known to have touchy throttles, but now because it's drive by wire and there's a way to reduce its twitchiness it's described as a killer flaw.
He'll probably win though.
When your throttle starts changing position from closed to 1/4 throttle without any input from the rider
"not for noobs" says it all. its a control issue
