Bunch of Misc. R6 & R1 YEC parts For Sale. All items are brand new in packages unless other wise noted. Paypal accepted but please add the 3.5% fee.
******'99-'02 R6******
USED KIT RACE HARNESS
Used Kit harness 5MT-82590-70 ('01-'02) removes unnecessary wiring circuits and has a ignition timing adjustment switch (used with kit ECU). This harness can be used with stock ECU. $150.
http://i427.photobucket.com/albums/pp358/Woodzee16/99-02 R6/B-43.jpg
******'03-'05 R6 ('06-'09 R6s)******
KIT YEC HEADGASKETS
Stock thickness is 0.60mm These bump compression slightly.
0.50mm thickness gasket (5SL-11181-80) - $40 each
0.55mm thickness gasket (5SL-11181-85) - $40 each
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7146.jpg
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7147.jpg
KIT YEC FORK SPRING SET
5SL-C3141-85 YEC Fork Spring 0.95kgf/mm - $65 per set.
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7143.jpg
FRAME & ENGINE PROTECTOR SET
1 - 5SL-C117G-70 YEC Frame & Engine Protector - $75.
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7142.jpg
******'06-'07 R6 (non s model)******
KIT YEC HEADGASKETS
0.50mm thickness gasket (2C0-11181-80) - $40 each
0.55mm thickness gasket (2C0-11181-85) - $40 each
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7149.jpg
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7150.jpg
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7151.jpg
YEC ECU CABLE W/SOFTWARE
'06-'07 spec. cable & software to allow PC access to modifiy your kit YEC ECU to make changes to the mapping, quick shifter, etc. $125 Shipped. (Pics soming soon)
KIT YEC TRANSMISSION
(**FITS '06-'11 R6) Offers different ratios than stock Transmission. To order new these are $4500 + !!
"A" set $1500 ...includes:
2C0-17402-70 Drive Axle
2C0-17411-80-A0 Axle Main
2C0-17121-80-A Gear 2nd pinion A
2C0-17131-80-A Gear 3rd pinion A
2C0-17151-71-A Gear 5th Pinion A
2C0-17161-70-A Gear 6th Pinion A
2C0-17211-80-A Gear 1st Wheel A
2C0-17221-81-A Gear 2nd Wheel A
2C0-17231-80-A Gear 3rd Wheel A
2C0-17241-80-A Gear 4th Wheel A
2C0-17251-71-A Gear 5th Wheel A
2C0-17261-71-A Gear 6th Wheel A
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7152.jpg
"B" set $1500 ...includes:
2C0-17411-90-B Axle Main
2C0-17121-90-B Gear 2nd pinion B
2C0-17131-71-B Gear 3rd pinion B
2C0-17151-80-B0 Gear 5th Pinion B
2C0-17211-90-B Gear 1st Wheel B
2C0-17221-90-B Gear 2nd Wheel B
2C0-17231-70-B Gear 3rd Wheel B
2C0-17241-70-B Gear 4th Wheel B
2C0-17251-80-B Gear 5th Wheel B
2C0-17261-80-B Gear 6th Wheel B
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7153.jpg
**Plus First kit transmission gets a free Tran. Maint. set a $75 value. Good for three rebuilds.
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7140.jpg
******'08-'10 R6 (non s model)******
KIT YEC FRONT FORK SET
Kit includes fork springs & Spring seat & spacers.
Part # 13S-C3151-85 (10.0 N/mm) $125.
Part # 13S-C3151-80 (10.5 N/mm) $125.
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7141.jpg
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7145.jpg
KIT YEC AIS PLUG
Used to block off the Air Induction System comes with all required plugs. $40
(Pics coming soon)
USED KIT YEC QUICK TURN THROTTLE
Used one season shorter stroke than stock comes with all cables, etc. and a free nice grip bolt & go. $200.
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/ForSale134.jpg
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/ForSale135.jpg
****** '02-'03 R1 *******
KIT YEC HEADGASKETS
*Stock thickness is 0.60mm*
0.55mm thickness gasket (5PW-11181-75) $40 each
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7121.jpg
****** '04-'06 R1 ******
KIT YEC HEADGASKETS
*Stock thickness is 0.40mm*
0.30mm YEC "skinny" head gasket (5VY-11181-70) $40.
0.35mm YEC "skinny" head gasket (5VY-11181-80) $40.
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7122.jpg
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7123.jpg
BASE GASKETS
*Stock thickness is 0.20mm*
0.15mm YEC "skinny" base gasket (5VY-11351-80) $40.
0.10mm YEC "skinny" base gasket (5VY-11351-70) $40.
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7128.jpg
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7129.jpg
KIT YEC COMPLETE GASKET SET
one of each gasket above in a kit of four (2 head gaskets & 2 Base gaskets for $125.
****** '07-'08 R1 ******
YEC KIT TRANMISSION "A"
Comes with:
1 - Part # 4C8-17411-70-A 1st Pinion (Axle Main A)
1 - Part # 4C8-17121-70-A 2nd Pinion
1 - Part # 4C8-17131-AA 3rd Pinion
1 - Part # 4C8-17151-70-A 5th Pinion
1 - Part # 4C8-17161-70-A 6th Pinion
1 - Part # 4C8-17211-70-A 1st Wheel
1 - Part # 4C8-17221-70-A 2nd Wheel
1 - Part # 4C8-17231-70-A 3rd Wheel
1 - Part # 4C8-17241-70-A 4th Wheel
1 - Part # 4C8-17251-70-A 5th Wheel
1 - Part # 4C8-17261-70-A 6th Wheel
1 - Part # 4C8-17402-70 Drive Axle Assy.
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7139.jpg
$1,500.
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7132.jpg
KIT YEC HEAD & BASE GASKET KIT
Comes with:
1 - Part # 4C8-11181-80 Cylinder Head Gasket (0.35mm Thickness)
1 - Part # 4C8-11181-70 Cylinder Head Gasket (0.30mm Thickness)
1 - Part # 5VY-11351-80 Cylinder Base Gasket (0.15mm Thickness)
1 - Part # 5VY-11351-70 Cylinder Base Gasket (0.30mm Thickness)
http://i427.photobucket.com/albums/pp358/Woodzee16/07-08 R1/07-08R1-HeadBaseGasketKit.jpg
$125.
YEC KIT SHORT STROKE THROTTLE
Part # 4C8-C6300-70 Throttle Set $425.
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7131.jpg
YEC SLIPPER CLUTCH ADJUSTER SET
Part # 4C8-A6377-70 This kit allows adjustment of the back torque limiter (Slipper) And comes complete with nut a shims to adjust the slipper pressure.
$70.
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7133.jpg
YEC KIT FRONT SPROCKETS W/ Nut (Fits '98-'11 )
17 Tooth Front 520 Sprocket with nut. $30 each
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7136.jpg
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7138.jpg
If interested please send pm..
Parts located in Courtice, Ontario (just east of Oshawa)
Thx.
KIT YEC HEADGASKETS
KIT YEC HEADGASKETS
KIT YEC AIS PLUG
(Pics coming soon)
KIT YEC HEADGASKETS
KIT YEC HEADGASKETS
BASE GASKETS
Comes with:
$1,500.
Comes with:
$125.
$70.
Thx.
