There's a bunch of clever people here I think you can help.
Buddy's old 340cc fan cooled kawi sled only runs on one cylinder. One carb with a Y pipe so I assume both sides get the same fuel. Swapped the coil leads and no change. Both side have decent compression. The only answer I can come up with is a bad crank seal on that side. There is likely a web in the case that supports the crank in the middle separating the cases into two separate halves and if one seal was bad enough it would be to lean to fire?
Thoughts?
Thoughts?
