Hi, Went for a quickie today. Stop the bike 3 times and the battery die the last time. Is there anyway to check the condition of battery without a multimeter? I have an R6 2009. Anyone knows if I should get a Canadian tire batter? thanks
stop wasting your time
go buy a new battery
and if his charging system is not working they way it should, he is going to buy a new battery in a week again....
it would make better sense to check the charging system of the bike and ensure it's working as it should, then look at the battery for issues.
yup, your right, don't check anything in way of charging system.....
just go and spend 70 to 150 bucks on a new battery and your issues will go away...
Real men own several multimeters.
Let me help you with this bike repair 101
1. likely an old battery
2. he wants to check the battery without a multimeter, uhmkay
3. battery has been charging over winter
4. battery is now dead and likely would need to be replaced...wait for it...wait for it...anyways
5. now you put in a new battery and check the entire charging system properly with a multimeter
6. he will have to replace the battery regardless...ride bike for an hour or 3 and check the battery again
7. now if NEW battery runs low he will know on restarts
NOW you know that you have another problem with the charging system likely the rectifier on that bike but none the less you will KNOW IT IS NOT the battery. Just put the battery on a good trickle charger and it will be fine.
or we would go with your idea and start replacing the MOST EXPENSIVE components to the charging system first.
new battery $40-$80 do it yourself 5 minute job + $10 multimeter
new rectifier iirc $300
new alternator I forget but likely in the $300+ range
labour to change the alternator, current shop rates ~$100 per hour plus taxes you can bet it will be at least 30 minutes
