Posted on the Vulcan forum but I thought I'd reach out to the vast knowledge here..
The brake light on my Vulcan doesn't work, whether I hit the front or rear brakes. I changed the dual filiment bulb, didn't help. Someone told me they had a similar problem in their car and used a screwdriver to adjust the socket a bit so the light fits tighter, there is really no spring to adjust on the bike but I did try holding the light in tighter and wiggling it a big (with a clean rag) while pressing the brake lever and it didn't help. I tried tracking the wire, there is a connection under the tank but I can't see it and can't figure out how to remove the tank - I can lift it a bit but the instrument cluster gets in the way and I can't figure out how to remove that!!
Wondering if anyone has experienced something similar, what could be the cause? Oh - I checked the fuses to. So it's not the bulb or the fuse. I do notice that if I press the rear brake, when I release it there is a very slight flicker in the bulb - only when I release it...it doesn't get any brighter of flicker at all when I press it down...
Thoughts? and THANKS!
