Rear view camera and GPS recommendation
victorbrca
I wanted to get a rear view camera installed on my bike that would plug into a GPS. Maybe something like this.
Anyone has any experience and can recommend me a model? Any shops around GTA that might have for a good price?
Thanks a lot!
Vic.
Did not have one that plugged into gps, but the one on my old bike had a separate monitor (just needed power, camera was wireless) that I mounted to my mirror stem. Worked great :D
Thanks a lot!
Vic.
The Magellan Roadmate 1700 has an input port for an external camera. $100 for a refurb at Tiger Direct. http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=6809987&CatId=4076
Seven inch screen. Screen brightness could be better but it is usable as is, and can be improved with a screen shroud. Speaker volume for speech-turn-instructions is right up there. You won't want to use the included mount on a motorcycle. Instead get a RAM mounting cradle for a Blackberry Playbook and modify the cradle a bit as the Roadmate is not quite as tall as a Playbook. A bit of hassle but not too hard to do with a small strip of of sheet plastic (plexiglass or lexan will work fine), glue, and basic saw. You don't need to cut the cradle. You just need to cut a couple of small strips of plastic to fit in the cradle ends so the GPS will fit within those two strips.
you need a rearview camera on a Ninja 250?? seriously, its not a Goldwing, turn your damn head and look over. Is this what we've reduced ourselves too...
What's the point of having a rear view camera on a bike? I don't get it?
at a light you can see if someone is going to rear-end you
[video=youtube;o7D0BTyJBeM]http://www.youtube.com/watch?v=o7D0BTyJBeM[/video]
woah... that was intense.
that's why I check my mirrors all the time when I'm stopped
Camera wouldn't have done any better than the mirrors in that case.
In this case a rear camera would have helped, luckily the guy was caught because he was considerate enough to leave his license plate at the scene;
[video=youtube_share;nHKD_GqxU9o]http://youtu.be/nHKD_GqxU9o[/video]
Wow.. that video enrages me.
Thanks a lot for all the replies. While the 7" GPS looks like a good purchase, I think it would be way too big to use it on a bike. I'm still searching for a smaller GPS that has A/V in. Something that would fit on top of my dash... like this:
Also, I was reading on the GPS A/V connections and they use different types. Here's a diagram for a 2.5 A/V input in case anyone needs.
I'll keep the thread updated with my progress.
Just go to costco and grab a normal wireless rear view cam and use that, then get a ram mount and put your GPS on your break res. :)
