I run the red all the time. In fact a few lights in my area that I know won't change I'll just look to make sure there's no cars around and go.
The correct answer is still right turn U turn.
Except if there's a divider/curb that prevents you from being able to do the u-turn. Then what? Travel all the way to the next block/intersection and do a u-turn in the intersection?The correct answer is still right turn U turn.
The light is defective if it doesn't change after a reasonable amount of time. Reasonable to me is at least 1:30. Some side streets onto majors just have a long cycle. If I see the crosswalk signal switch back and forth between walk and hand without the actual traffic light changing, then I consider the light defective/malfunctioning. Report it to the municipality or they'll never fix it, and get some kind of reference number. If you get caught running the malfunctioning red, at least you have a record of it's malfunctioning state.
This IS illegal. you can't get off your bike in traffic.
what i am waiting for is the day i am at a red light and a cop is nearby or even behind me. i will proceed to make a left turn on the red and i wont get a ticket
special circumstances are. you have to wait until it is safe to do so, no cars coming and no pedestrians. AND you have to be turning onto a one way street. There are several
lights and streets like that around here. Most drivers i quiz do not believe me.
i would love for a cop to pull me over to give me a ticket for running the red and i will tell him to look at MVA 129-4b
Motor Vehicle Act
129
(4) When a red light alone is exhibited at an intersection by a traffic control signal,
(b) except when a left turn permitted by this paragraph is prohibited by a sign at the intersection, the driver of a vehicle facing the red light at the intersection of not more than 2 highways, and which in obedience to it is stopped as closely as practicable to a marked crosswalk on the near side of the intersection, or if there is no marked crosswalk, as closely as practicable to the intersection, may cause the vehicle to make a left turn into a highway on which traffic is restricted to the direction in which he or she causes the vehicle to turn, but the driver must yield the right of way to all pedestrians and vehicles lawfully proceeding as directed by the signal at the intersection
Take a good look around for police or red light cameras.
Make your decision.
Accept consequences.
Problem solved.
