Looking for a shop that is good at diagnoising and fixing a stock Suzuki GSXR750 2003.
The bike will not rev up past a specific point. When it picks a point it will always be that exact RPM point. Position of throttle or the pace at which I open the throttle has no effect. Gradually the rev limit is dropping over months. At a certain point it is like a SOFT rev limiter cuts in.
Just below that limit it will run all day long like nothing is wrong. Say 100 rpm below the cutting out spot. This has been an onging problem for a while, 20,000 kms!!!. The local dealer is useless for help. I can only check so many things due to equipment....
New:
- fuel pump/filter/regulator assembly
- TPS (Throttle position sensor)
- battery
Used:
- ECU
All sensors voltage in/out and to ground checks are ok.
MAP (IAP - Intake Air Presssure)) sensor vacuum checked ok.
Checked and cleaned the CKP, crank position sensor. Dealer checked Peak Voltage on CKP.
Dealer said fuel pressure may be 38 psi but they were not confident in their gauge. Spec is 42 psi. So I put a new one in.
The bike does not have a dust bunny or corroded spot on it. Clean as a whistle as they say, inside and out.
Does not burn a drop of oil, litrerally, between 5,000 km oil changes.
No fluid leaks.
Frame, grounds, connections, fuses and fuse boxes are like factory new. As are all electrical connections.
Inside the fuel tank, fuel rails are spotless clean.
Air filter and intakes clean.
New sparkplugs.
Ignition coils resistance check ok.
Fuel injectors pass electrical checks per Haynes manual.
Visually inspected each fuel injector's inlet screen filter which appear clean.
No unusual noises.
No codes on dash.
It does it in any gear (1st to 6th), on the sidestand in neutral or in neutral with the sidestand up.
Bumps have no affect. Rain has no affect.
Bike stored indoors always.
Seafoam fuel injector cleaner recently tried.
I put almost 7,000 kms on this bike in the past 3 weeks. The limit, cut out, rev no higher is now down to a new spot. No more trips until it is fixed.
When it cuts out say at 10,000 it will climb to 10,500 chugging, max. But no higher.
Its new limit is now 7,000 rpm. Chugs up to 7,500. Will run at 6,800 all day long just fine.
Always starts instantly and runs great until a point.
Help, please.
New:
- battery
Used:
- ECU
No fluid leaks.
New sparkplugs.
No unusual noises.
No codes on dash.
Help, please.
