Recently I had my stator fail. The insulation of the coil at the top position melted and the rest is history. I have gotten another stator and so far so good. Being tossing around some ideas on how to have it run cooler. I am considering a mosfet RR since there is one available for my bike from RMstator. By the sounds of it, the mosfet will run cooler but I can't really find anything about the stator running cooler. Some say it makes heat when not under load and others say the opposite. So my question is does a stator run cooler with a mosfet RR?
I have already changed my headlight to led long before this happened.
Also considering methods of cooling the stator such as a heat sink on the cover, oil line from the sump through the stator cover to dump oil on the stator, etc.
