Thinking of getting a full system akra, as this is somewhat out of my comfort zone id like to get reputable shop to get it installed and done proper, anyone got any recommends?
Or is the dealer the best bet?
bramptonWhat area are you in?
brampton
you can make your bike stock again a few minutes?I was thinking of going to Pro 6 as well and was quoted the following when I asked how much it would cost to get a Rapid Bike EVO installed:
"This job would be approximately 1 hour at $110/hour.
Labour on emissions block off and accessories such as quick shifters and O2 sensors will be extra."
I'm curious as to what the difference / benefit is between a full factory ECU reflash/remap vs a piggy back system that ties into all the sensors and injectors..
Theoretically piggyback can help you keep your warranty (morality aside) and flash will kill your warranty. Not sure how bike manufacturers are dealing with this though.
uh flashing?If you can remove an aftermarket full system and install the original pipe and headers in a few minutes, then I'll be impressed as hell!
you can reflash your bike to stock before taking it in.Theoretically piggyback can help you keep your warranty (morality aside) and flash will kill your warranty. Not sure how bike manufacturers are dealing with this though.
uh flashing?
I had my Yoshimura system installed at Powersports T.O. - New & Used Motorcycles, Service, and Parts in Toronto, ON, near Mississauga and Ajaxanyone got any recommends?
what a bunch of wussies!I had my Yoshimura system installed at Powersports T.O. - New & Used Motorcycles, Service, and Parts in Toronto, ON, near Mississauga and Ajax
I had to wait a bit as they couldn't start work until the exhaust pipes had cooled down after I rode there.
No they don't. Knowing that it was flashed outside of the dealership environment is enough to win against powertrain claims. They can rightfully argue that they have no idea what happened but something had been changed without their knowledge or consent. Car manufacturers routinely deny warranty claims even if they were flashed back before service and afaik, they haven't lost in court on that point. Now if your front brakes fail, flash count should have no bearing on the claim.and they still have to prove your flash caused the issue to void the warranty.
