Front Brake Reservoir 2008 suzuki gsxr600
Morbeca
Hey peeps! My front brake reservoir is broken and I just ordered one but the one i just got is a lot smaller than the original one. Would that be a problem if it's smaller or should I just return it and get the same size? Thanks for the help. Much appreciated
I'm Close to Pickering, I may have an OEM one around somewhere. I'll PM you when I get home tonight.
As long as the hose fits on properly and you can mount it you won't have an issue. It just becomes a bit more of a pain to bleed the brakes because you have fill the resivour more often.
thanks for the advice. I'll rather put one similar then, don't want hassles :)
It will be fine. Just make sure the hose fits well and mount is secure.
My 07 had a recall on the brake reservoir. Call it in and see if it's covered. Had mine done last year
