So, I put an integrated rear light on an R1, hook up the resistors (20W 5 ohm) to each signal, works great. Put led signals on the front also, (Each signal has 14 led's in a cluster) I hook up the same resistance and only 4 of the 14 led's light up. It blinks slow like its supposed to do with resistance but why only 4 led's lighting up? If I bypass the resistors in the front it blinks fast, as expected, and ALL led's light up properly. I'm stumped as to why only 4 out of the 14 led's light up in the front signal when the resistors are hooked up.
Any insight to this would be appreciated, thanks.
