Norcorider
I have a 2002 Kawi zx6
I had rebuilt carbs 2 seasons back and everything was fine till I noticed last month that one of the float bowl was yellow from outside. On touching it , it smelled like gas.
I thought maybe the float bowl gasket has gone bad (since it was aftermarket rebuilt kit). so I order OEM gaskets and replaced all 4.
Since, I had float bowls opened already, I also took out pilot and main jets and sprayed them with carb cleaner, also sprayed carb cleaner in the carb body(without completely disassembling it.)
Put everything back together and bike started fine. Was revving freely from idle.
Took it out on a ride last weekend and it's bogging on sudden full throttle, for example on quick passes.
If I close throttle gradually , or keep it open a bit longer, bog goes away. On gradual opening of throttle , no bogging.
Any ideas what's going on?
I was talking to a gentleman I met at Belfountain on the weekend , and he said it might be running lean.
I didn't touch any mixture screws when I put everything back together.
Lastly, the air filter was dirty, so I cleaned it with a compressed air can. But when installing it back , I installed it with yellow side facing up ( it's a dual stage foam filter , one side is yellow other is gray. It was installed with gray side facing up , which I thought was wrong,so I reversed sides when reinstalling, Could this be causing the issue?)
![95a4af48ad6264782f1e8648c4646fa4.jpg](http://uploads.tapatalk-cdn.com/20240611/95a4af48ad6264782f1e8648c4646fa4.jpg)
![4f67bcbfc134f4bd2f11465af8c437f5.jpg](http://uploads.tapatalk-cdn.com/20240611/4f67bcbfc134f4bd2f11465af8c437f5.jpg)
![c7060f7678d4df71b166d1306ea5e04c.jpg](http://uploads.tapatalk-cdn.com/20240611/c7060f7678d4df71b166d1306ea5e04c.jpg)
