I hadn't charged it since a few months ago. I assumed it was a dead battery, but it measured 16V. I didn't notice if it was hot when I did charge it.
I tried to put it on the charger before I was able to get a hold of a multimeter to measure the voltage, and the current from the charger read 3A, which seemed high. When previously charging, it was in the mA range.
I just put the battery back in and tried a start. When doing so, I measure the voltage at starter relay. Before starting, the voltage reads the same as the battery voltage, but, upon pressing the start button, voltage drops to 2V. I'm not sure if this is a defective battery or starter?
Any suggestions?
