Hi all; I need some help and guidance if you may. Let me of course first say I have read all of the other threads that mention this what seems to be rare problem, but I am not very mechanically inclined. I do also recognize that I have not contributed to this forum, but I will process a donation to this website for your help. I will do my best to describe what was done, what i've tried, and the symptoms.
2006 R1 Anniversary with full Akro Evo, PCIII, 30,000KM. Located in Hamilton
Symptoms: Check engine light 48 - throttle servo motor stuck, no power above 7000RPM.
I recently had the stator replaced and it rode fine for around 200KM and then threw this code 48. I managed to figure out how to get the tank up, and the airbox off. At that time, I just pressed on all the connectors I could see around the throttle bodies and put it back together after charging the battery completely ( it was an older battery ). I should also note at this time I did notice the motor working as the top butterflies were opening and closing when I turned on the key. To my suprise, the bike ran great. Code disappeared and it was perfect. For around 200KM- the code came back.
Now I figured out how to completely remove the tank, airbox, etc. This time, when I turn the key the butterflies do not move at all and I cannot physically push them open as if they are locked. If I spin the worm nutt on the top of the sub throttle servo motor they do open and close properly but they are physically locked if I try and press them - not sure if this is normal condition. From the top I cannot reach from what I find in pictures is one connector, I do see the other sensor connector on the side. So that is my dilemma and here is what i've gathered from my reading and seek your recommendations.
1) Could this be a fuse? Which one, and where would I look?
2) Can I get at the connectors if I remove the fairings or does the whole throttle body have to come off?
3) Could this have just been a symptom of a bad battery - does the Code 48 being still active in the memory cause it to not run the checks during key turn? Do I just need to reset?
4) I do have a 'volt meter' but not sure how to use that to test the motor itself
5) Is it normal to not be able to press the butterflies open by hand - but the worm nutt does? Did me spinning the nutt by hand lock something? IE; did I tighten it preventing it from moving?
6) I did today just a few minutes ago install a brand new battery and pulled the fairing off. The connector for the motor seems to go up to the front near the fan but I can't get at it. The mechanic that replaced the stator also replaced the spark plugs so we were working up in that area but I can't get at it without getting the rad off. Even with the new battery, the butterflies now do not move on key cycle.
It is odd to me that it is so intermittent, I wonder if it's an electrical issue as the stator was just replaced, but i'm not even sure where to start with that. Is there any way to un-stick this thing?!
Again, thank you for taking the time to read my thread and with hopefully your help a not-so-mechanical man with some direction. I was able to order an entire new throttle assembly with motors and sensors today online - so maybe if there are any mechanics or race guys familiar with this that can help or give me an idea of time / cost to just replace the whole assembly. I don't want to go another summer without my bike.
Appreciate it.
T
Appreciate it.
T
