Parting out a complete F4i engine, this is a running engine with a jumping 2nd or 3rd gear. I wanted to see if anyone here was interested before I put it up on EBAY.
I'm hoping to part it out in the respective assemblies,
1) Head Complete (assembled) - Head, Head Bolts, Cams, Cam Tensioner, Cam Gears, Top Chain Rail, Shims, Valves, Valve Springs, Valve Retainers, Cam Cover with Bolts
2) Engine Main Cases - Top (cylinders & bottom) with sump cover, Oil Pick-up, Baffle, with all bolts
3) Complete Transmission Gears, Forks, All Shafts, Clutch Assembly, Shifter Shaft, retainers and bolts
4) Complete Crank (assembled) with Flywheel, Starter Gear and Ignition Wheel
5) Pistons and Rods complete (assembled)
6) Stator Cover Complete with Coil and Bolts (aseembled)
7) Clutch Cover with Ignition Pickup and Bolts
PM if interested.
PM if interested.
