maybe you're mistaking what i am replacing here
this is only a bracket that attaches which will hold the footrests that's all.
That might be why you took it off, but there's a reason it's called a swingarm bracket on the parts diagram. That 20mm nut you removed wasn't just holding on the bracket, it holds the swingarm shaft in place.
huh! i see what u mean. i didn't have a torque wrench that locks with weight settings. so i just paid attention to how much force i had to give it when i removed the nut... then i applied the same amount of pressure tightening it.. but maybe i will look into buying a proper torque wrench and give it a test before i take it out for a ride!
Over torque or under torque, either is bad. Did you happen to notice if there was any lock tight on it? You can't just remove a swingarm nut and tighten with feel, it needs proper tq specs , they are there for a reason.
LocTite is a thread locker adhesive, it prevents nuts/bolts from coming loose, use the blue version it's not as strong and it will allow you to remove the nuts and bolts at a latter time, the red will be a pain, and usually needs an impact gun to remove
and you probably should get a torque wrench, and have that nut/bolt tightened to spec
http://www.loctite.com/index2.php?cc=ca
can be purchased at Canadian Tire
Then the factory is relying on the proper tq to keep it in place
I believe that is the same one as I have, I have no issues with it, and I have used it to rebuild two bikes so far..
What about the bearings in the swingarm pivot?
Needle bearings what about them, torque on the shaft has no effect on the needle bearings. They simply pivot on a shaft. Its just a pivot shaft, not rocket science. Im all for doing things properly and having the right tools for the job, but for this guy to go out and buy a torque wrench to tighten one nut seems unnecessary to me. Good tool to have I guess, if hes up for it, personally if I was going to invest in one Id buy something higher end
Id trust my own feel over a power fist tool personally
