Not to sure what parts i need.
It's unlikely the bar-end itself needs to be replaced (unless it's scratched up and you would like to replace it for cosmetic reasons, which is fine) just the bolt holding it to the handlebar
if the throttle drags you may want to replace the handlebar. look closely. test for drag. when and if you do change the handle bar, just loosen all the parts on the handle bar enough to slide out the old handlebar - and then slide in the new handlebar, don't take everything apart.
