GARAGE CLEAN UP !!!! Tons of Busa parts.
BOREDOM
Active member
FOR SALE :
ALL GEN 1 BUSA PARTS............
Black, billet rear sets, with brake switch, made in the USA not CHINA crap.
$150 , will fit gen 1 & 2
6" over Busa arm. with extended chain guard. all bearings and brake bar. ready to go. swing arm also has hook ups for a wheelie bar. if interested I can include the wheelie bar set-up. or just the arm.
$250
OEM Busa wheels, including rotors, good tires, vortex sprocket, hub, cush drive, bearings etc. the wheels are complete.
$350
OEM Busa rear wheel, with cush drive, bearings & rotor
$150
Busa subframe with "removable" additions to fit an extended tail sect. includes tiger undertail.
$150
Busa, cut rad, professionaly cut and cleaned up by Carpenter racing in NJ
$150
Busa calipers, resevoirs, braded brake lines, rear master & front master
$200
Busa, oem tripple trees complete, upper & lower, with billet top clamp for lowering, includes clip ons. bearings, bolts, nuts, everything.
$150
Busa complete gen 1 body, with headlight, integrated, smoked tail light, and extended one piece race tail, body is oem 2007 red, with flames airbrushed. includes sides, fender, head fairing, gas tank, extended tail, seat. all in great shape and ready to go.
$800
Busa oem rear shock.
$100
Busa, clutch cable conversion, includes everything you need, clutch set-up, push rod, sprocket cover, clutch cover, clutch perch & lever, clutch basket, plate, springs, clutch cable, and clutch plates absolutely everything you need,
$500
Busa oem rear sets, will sell as a set or split up if needed. $60 for the set or $40 each side
Busa oem front fairig stay / bird cage.
$100
ALL PARTS ARE PRICED TO SELL !
Pm for pic...... located in Toronto
