Fs: 2006+ gsxr oem and aftermarket parts
slegato
Active member
# cost (each) item
1 $600.00 complete engine
1 $160.00 complete bike wiring harness
2 $100.00 oem suzuki clutch kit (new)
1 $60.00 k&n filter
2 $40.00 ignition coil set
1 $100.00 stock fuel pump
1 $40.00 ngk iridium 1x plugs - set
1 $40.00 ngk plugs - set
1 $40.00 oem header
1 $20.00 engine coolant hose set
1 $20.00 engine gasket
2 $20.00 exhaust xup cables
1 $20.00 overflow bottle
2 $20.00 oem air filter
1 $20.00 new triple tree bearing
1 $60.00 stock shock
1 $60.00 ohlins spring 01093-29/90 l148
2 $20.00 oem front damper
3 $20.00 oem rear rotors
1 $60.00 oem brake master cylinder
2 $40.00 new front brake pad sets
1 $20.00 oem brake resevoir
1 $100.00 rear cush drive/captive spacer/renthal sprocket kit-47t
1 $80.00 rear cush drive/captive spacer/vortex sprocket kit-47t
2 $20.00 cush drive bushings - sets
1 $20.00 afam front sprocket - 16t
1 $20.00 vortex front sprocket - 16t
1 $50.00 sharkfin
1 $20.00 swing arm spools
1 $20.00 used frame slider set
2 $40.00 carbon frame slider set
1 $40.00 new 08 gsxr 600 windscreen
1 $20.00 double bubble windscreen
2 $20.00 oem used windscreen
1 $20.00 hotbodies windscreen
1 $10.00 brake/clutch switch
1 $10.00 medium grip set
2 $100.00 oem complete rear sets
1 $60.00 oem partial rear sets (shifter missing, brake lever bent)
1 $40.00 aftermarket clutch shorty lever
1 $60.00 hindle stand
1 $20.00 yamaha stock lever set
