ex250 timing marks and manual help ?
HERBXX
Does an ex 250 have timing marks on the flywheel that can be seen by removing a plug ? I'm working on an bike that I suspect has a damaged cdi unit as the regulator was bad and fried the battery and a few bulbs. All of the fuses have benn checked and are fine .
The bike runs with a new regulator and battery , but will not make much power , I suspect the timing advance section of the cdi unit has failed ?
Thoughts ?
Also a link to a pdf manual would be helpful .
thanks
Herb
