Rebelrider1
Does anyone know if I need to pull the maxi fuse before I disconnect the battery. I have an alarm system on my bike and last year I didn't have a problem when I took the battery out but Oboy - when I put the battery back in it screamed at me. So I was thinking if I pulled the maxi fuse - that would disarm the alarm.
Also I tried some searches online. The HD site said I can put the ignition switch to ON along with the Fob. I've never taken the battery out with the bike in On.
- Remove the seat. See Seats and follow procedure for the appropriate model.
- If equipped with security system siren, turn the ignition switch ON with the hands-free fob present to disarm the security system.
- See Battery Connections. Loosen bolt and remove battery negative cable (black) from battery negative (-) terminal.
- Loosen bolt and remove battery positive cable (red) from battery positive (+) terminal.
- Lift battery from battery box within oil tank cavity.
