LCDshovel2007
New member
Hi everyone, and thanks in advance for your help.
I have a 1994 Kawasaki Ninja 500 (EX500) that only runs on one cylinder out of two. I was riding on the highway when I felt a significant loss of power and lots and lots of backfiring out the one side which ended up being bad. I figure I need a valve job at the very least.
Here's the troubleshooting that I've done so far:
The good cylinder gets 180PSI compression, and the bad one gets none at all. Adding a bit of oil into the cylinder doesn't change the reading. I blew compressed air into the spark plug hole while manually turning the crank with the exhaust off, and it seems like the air is always leaking out of the exhaust. This leads me to believe that something is wrong with my exhaust valves in that cylinder.
Aside from that, I've cleaned the carbs, making extra sure the pilot jets were fine, and set float heights to spec with a digital caliper.
Also did a valve adjustment. All the exhaust valves were a little out of spec (too tight) but the intake valves were okay.
Coils are fine too, although I did trim the spark plug leads and put new caps and plugs just because. Switching coils gets the same result - runs well on the right cylinder, doesn't run on the left. Even replaced the IC igniter.
Unfortunately, I don't have the time to learn how to remove the cylinder head atm, otherwise I'd have a much better idea of what's going on.
So far, I feel like I've ruled out spark and fuel issues, and the zero compression is a huge clue. Correct me if I'm wrong, but I'm looking at a head rebuild to start? If so, where do you guys recommend? I'm located in the Kitchener/Waterloo area but I'm willing to travel. Any stories of similar experiences and time/cost figures would be hugely appreciated! Thanks!
