I probably posted this before & I'll post it again. The sprocket at the front kick out alot of grease & coats the neutral sensor. I believe this sensor is magnetic & when it becomes coated it will not work.
However, this doesn't mean you can't find neutral. Just close your eyes & feel for neutral. You'll find it.
the sensor is not magnetic
it doesnt' get coated on this gen
Wait, what was the issue?
can you not find neutral?
I can’t find neutral in my 2010 GSXR sometimes. No green N light and the indicator is blank. Is that your issue too?
Do you mean there is no green neutral light? Or you literally can not find neutral
You have the dirty connector issueNo green light and no 0 for the gear indicator. I can find neutral, but the bike can’t (wont register it on the cluster)
Wouldn't there be a way to wrap it in some kind of film or protection? So it doesnt dirty up the actual sensor and just whatever is wrapped around the connector and sensor?
