Need to insulate the single car garage so I can spend more time out there during winter in reasonable comfort.
I need to insulate the door or replace it (even though it's a great door - it's just not insulated).
I need some good weather stripping too if I'm keeping the door.
I need to add insulation to 2 walls that are not contained in the house and suffer the most heat loss.
I might do the floor, but that will probably just be a coating so I can clean it up easier.
Budget as always is limited!
I will go to Home Depot and talk to the smart folks there, but was curious what the GTAM input was.
Anyone here used the insulation panels you add to existing garage doors? Pros / Cons / issues?
Anyone here used garage door weather stripping and have some preferences?
What type of insulation would you use in the walls and why?
Thanks!
Thanks!
