cuteblackfox
All taken care of
I have a 2008 Kawasaki ninja 250
did an oil change. Then next day went for a ride and bike came to a stop on the highway!!!!
sooo I figured out where the oil leak came from... (silver hole)... hole is beside the oil filter mount, not the oil drain plug either...anyone know what the hole is called? And why is it leaking from there?
Thanks
Still can't see your images.
Either way, you probably want to start looking for a used engine, as yours is probably toast and even just verifying that it's toast could be expensive
I didn't do the oil change myself
As suspected the oil is not coming out of the silver hole. you didn't tight the oil filter cover properly (or whomever did the oil change)
Thanks
If it was a shop, bring it back there (don't ride it if you get it working)
If it was a friend then go back and answer all my questions above.
Thanks
