catzo
I've got about half an oil change worth of Rotella t6 5w40, and half an oil change worth of Mobil 1 synthetic 10w30.
Safe to mix?
Safe to mix?
I'm no oiloligist, but I would have no problem mixing brands. Viscosities however, I would be reluctant.I've got about half an oil change worth of Rotella t6 5w40, and half an oil change worth of Mobil 1 synthetic 10w30.
Safe to mix?
Do not mix that if your bike recommends 5w40.You're basically thinning your oil
Whichever is cheaper. Pretty much the only reason anyone runs T6 to begin with.Speaking of oils....I found a rotella T6 thats 5W-40 and one thats 0W-40....(Both synthetic)
why would they make 2 oils that are almost essentially the same(One being SLIGHTLY better in colder temps)
I know the T6 has a great rep for bikes...I wonder which one most riders use out of the two weights?
If your engine never hits 100C then that's fine but what if you hit traffic? Pray that you don't put unnecessary wear on your engine?It might still meet the target if checking viscosity/temperature table in owners manual and needing to leave town quick.
FWIW I've been wearing the same sneakers and track pants so long that the threads are disappearing on them as well.
Coincidence? I think. Not.
Sent from the Purple Zone
Seems so.
