Just got a Yamaha 2008 WR250x.
When I abruptly apply the throttle, the engine dies. If I slowly roll on, it revs up as normal. If you abruptly apply the throttle with the revs already a bit higher than idle, then it hesitates but does not die.
The previous user has a FMF power programmer with a FMF Q4 full system. I thought I might have changed the settings by accident and caused this, so I disconnected the programmer. It's still doing it.
I can fix things if I know what the problem is...but I have no idea what's causing this.
The air filter is clean. I also replaced the spark plug too. It was all sooty and a matte black.
Any idea where to start?
Thanks!...trying to get this going for some ice racing this winter!!!
