bluecorvin
I need some ideas on what is going on with my 89 K100 rs. I have not touched any of the wiring connections on this bike EXCEPT for then ones going to the cluster to connect a new Digital smaller unit.Everything looked good when I turned the power on except that the neutral light will not light up, and the Oil preasure light will not light up either. Double checked my connections and they are good and the wires that I Picked are the right ones too. Why I don`t know.
My biggest problem is that the fuel pump is not getting any power and the fuse that controls the fuel pump unit is good but NO POWER at all at that fuse block. As a matter of fact that is the only fuse that don`t light up.
I had the ABS removed from the bike but only the mechanical part, everything else is the same as it was when I rode it home and everything was ok and working.
Stuck at this moment and wondering what to do next, I am open to any ideas and sugestions and will provide you all with feedback as I go. Thank you in advance Alex
