sesamestreet
All done
brakes are usually simple
noises caused by brake dust build up
worn pads
stuck calipers
uneven rotors
when was the last time you changed the pads? how many kms ago?
you probably at the wear mark on pads
I replaced my rear brakes (with OEM parts) about a year ago, probably under 10000kms of not too aggressive driving. Some of my coworkers (lexus techs) said it might be suspension noise too but it only happens when I apply the brake, and only seems to come from the passenger side. there's a variety of noises happening, a groan-like noise and a light scraping noise that both follow the rotation of the wheel. I know it's not diff noise or anything like that.
that's not it either as I've had the wheels switched a couple of times and the noise persisted. I usually do the wheel swap in the shop I work at (in parts) but this last spring I did them in my garage. checked torque, that's not the issue.Sounds like the wheel could be loose. A loose wheel would make the rotors shift (scraping noise) and groan on braking.
I had a really weird grinding sound coming from my rear CV when slowing down. Really didn't sound like a CV. Oh wait, mustangs are not there yet, don't worry about it
only happens on brake though so not sure! but alas, I am taking it to WK PERFORMANCE in Hamilton, a specialised mustang shop. seems like all my car/moto errands are in Hamilton these days, between sturgess and now this. Which reminds me I have parts to pick up from sturgess!Light scraping noise. Wheel bearings maybe?
