What's your tow vehicle?
Just because the rack is rated for 600lbs doesn't mean that your vehicle can carry it. You've got to check the max tongue weight for the hitch *and* your tow vehicle. The actual weight you are able to able to put on the hitch will be the lesser of the two, also accounting for the weight of the rack itself as well.
For example, I doubt you'd be able to carry a 400lb sportbike on the back of a Honda Civic.
I could be wrong but here is what i know from research....
Towing spec does not apply to the carrier. The max torque rating is for the hitch. So you need class 3 and above.
The only passenger vehicle that has class 3 hitch as standard is Subaru Legacy.
The weight loading of your carrier must be less than your vehicle carrying capacity ( Gross weight - curb weight) and the rear suspension spring rating.
So..... The vehicle im planning to use is ..... Camry V6. Gross weight is 4400lbs, curb weight is 3400lbs. So i have 1000lbs for me + bike + cargo.
I have to get a custom class 3 hitch. And hope that the rear suspension can handle it ( or upgrade the spings)
Thro my search i see many adv riders use this system with their minivan for their supermoto
