Riceburner
Can you run a 35mm positive offset rim on a car that is OEM 40mm offset....if the tire + rim combo doesn't touch anything? What potential problems could there be?
If the 35 offset rim is wider it will be closer to the suspension by 5mm plus half of the extra width.
That sounds right. So as long as it clears the fender and brake components it's fine.You have it backwards. A lower offset will poke (rim+tire will be moved outwards closer to the fender).
Yep same scenario. So a 5mm less positive should be nothing. Old rims are 35, new car OEM is 40.I just got a set of rims from the Tire Rack. They said that these will fit, so I am sure they are right. Just to give you an idea, it is somewhat similar to your situation, I am moving to a lower offset. The OEM offset is 52.5 mm, the new rim's offset is 45 mm.
Positive offset is always better, than a negative one. It minimizes the strain and wear on ball joints and etc. This is exactly why you see it on most OEM cars, though it's not as flashy in rim selection.
Virtually every car runs negative offset.
Wrong.Virtually every car runs negative offset.
Nope, almost the opposite I think. Almost every FWD and newer RWD runs positive offset. Those big rims with a deep set rim are negative offset. Any with the face of the rim close to the outside is a positive offset.
Negative offset:
Positive offset:
