So the next question -- Does the average urban rider and sometime touring rider need a quick shifter? I was thinking it may be bit of a safeguard for those bad shifts that can happen from time to time. A quick shifter would give you some latitude for making mistakes. BUT -- It also stops you from getting better at shifting.... sooooo ?
No. In fact, a quick-shifter can be a royal pain for street riding. An OEM installation may be different, it may account for some of the issues. But ...
When street riding, I always feather the clutch during gear changes - lightly almost-but-not-quite disengaging it - so that the gear change is as bumpless as possible.
I have a quick-shifter on one of my bikes, which has seen the drag strip a few times, and that's why I put it on. This is the aftermarket PowerCommander one which cuts fuel delivery.
The problem with having this during normal riding is that if it cuts the engine during my clutch-feathering, the engine loses revs and instead of being a smooth gearshift, it becomes a HUGE jolt. If it does its thing at full throttle (me not using the clutch) it's fine. If I do my thing at part-throttle (without the quickshift) it's fine. When both try to act together ... Bad!
YES, you can set up the quick-shifter so that it only acts above a certain RPM, but typical PowerCommander, it's inconsistent and sometimes does its thing below that RPM. You can set it to only quick-shift near redline, and if the PowerCommander were to reliably do that, that's fine, but for commuting, obviously it isn't going to do anything.
I mostly-fixed this issue with a $4 microswitch installed to detect the position of the arm that disengages the clutch. If the clutch lever is not pulled in, the switch is closed. If the clutch lever is pulled in even slightly, the switch opens and blocks the signal from the quick-shifter switch. It's not perfect; if I get the timing of clutch and shifter off a bit it will still let the quick-shift happen even though it's already in the next gear. But it works about 95% of the time and I can deal with the rest.
An OEM installation might be smart enough to handle this properly; that needs to come from owners of bikes with OEM quickshifters ...
