5:12
hi peeps,
i think i used a correct title, if not, let me know.
i'll use a specific oil designation for ease. what would be the negative effects, if any, for using a 5w-40 during warm/hot weather instead of 10w-40 or 15w-40 etc. notice the focus is on the first number (cold temp designation/rating).
let me add on to this, let's say the bike calls for 10w-30 for cold temps and 20w-40 for warmer temps. so 10w-40 would ideally cover the suggested oil grades for all temps, but instead of this, 5w-40 is used? since the bike calls for a 10w-30 for cold temps, will 5w-40 be simply too thin during cold temps? now what would be the ill effects if the oil is too thin?
so 5w indicates that it would be thinner in cold temps compared to a 10w. im thinking, provided that the temp doesn't drop to what the 5w is designed for, then the oil wouldn't really be as thin. does this make sense? essentially, 5w-40 would function the same as 10w-40 except in cold temps. no? and the bike wouldn't really use that '5w viscosity rating' unless the cold temp requirement for the oil is met (?).
i know some here would say follow what the bike manufacturer suggests etc etc., ok, but i would like to get some informative input here pls pertaining to the question. thanks.
5:12
5:12
