Because kawasaki screwup something on this model 1998-2002 horizontal mounted filter you must release air or oil light will stay ON ''Loosen the oil filter and start bike. The oil should come pouring between the filter and engine block. Tighten filter'' (this is called BURP)--this is from kawasaki forum--, and I bought this bike this spring and I dont know anything related to previous problems if there is any. Honestly Im not bike expert Im nurse LOL, but hey thanks for replying
hahaha well thats good, no they say that may not be on every zx6r 1998-2002 but its possible and need to be aware of that, but hey thats what I read on kawasaki forum and internet who knows LOL
This is sample and there is bunch of that related to zx-r 1998-2002:
http://kawasakiworld.com/zx-12r/3830...-psi-help.html
cheers
hey galvanize what colour is your 98 kawi?
I'd really make sure the plug gaps is correct and that all your wires are seating properly.
"ride to your full potential or why ride at all!'
04 R6 (sold)
07 R6
i am in hamilton i can swing by and have a look if you want.....
Did you check the oil again after you "burped" it? Maybe you "burped" out too much oil... I can see the idea behind it but that sounds... wrong. Couldnt you just fill up the filter with oil before putting it on? Lots of things have horizontal mount filters and ive never heard of having to burp them...
Could it be that your oil and plugs are OK and the problem is the connection to your fuel tank? I assume you had to remove it to get at the plugs. Check the fuel lines and any electrical connections that you may have came across while under there.
OK my bike is crazy, today not even to start, all I can hear is loud click under my seat when I try to start
Hey bud, today I get brand new battery and guy told me it could be bad plug, so I check , and cylinder number 4 doesn't work I mean exhaust is cold on that cylinder, and again I get new plug take everything apart etc.. I was hope that would fix my problem but not, now it could be carbs but I have no idea how to clean carbs hahaha or something else ...
I can help you pull your carbs and clean them... But is cyl # 4 firing now after you put new plug in?
check for sparks, if no spark on #4, could be ignition wire faulty......
Bookmarks
