If its not a charging problem and you have replaced the battery-
this may be one of the Sh**tiest problems you can have..
It most likely that you have a short somewhere. Was it wet/raining when this happened? could be moisture related, something not sealed or closed up properly.
did you do any electical mods? check those first.
if not...
You need to take a voltmeter and test the bike in sections up and down.
b4 you do that- double check the connections on the fuse box.. occasionally it can be due to a loose fuse.
good luck
Bookmarks
