Have you pulled any fuses ?
08 gsxr 600. start button doesn't start the bike. Tested the switch and its fine, even swapped it out for another one. bike will run when the starter solenoid is jumped. changed the solenoid, and all the relays. The only things that aren't on the bike are the headlights and tail lights.
Do the lights turn off when you hit the start switch at all?
EDIT: I guess you need to have the headlights and tail lights installed to find that out.... lol
Clutch switch. Bypass by crossing the two black w/yellow wires.
For fear of sounding slow here, shouldnt this be a warranty issue ?
The artist formely known as Frenchfry
tip over sensor?
kinda, tracing them in the harness isn't easy. was wondering if there was anything else inbetween (other then the wires) that I've missed. only one wire from the switch the same colour at the solenoid, the other wire at the solenoid is the same colour as the one at the clutch swtich which I was told to check today, after I'm done eating lunch I'm going to jump the clutch wires where the left clipon plugs into the main harness.
Side-stand switch??
Bookmarks
