You winOriginally Posted by Duster929
Actually, I was almost convinced it would fly, but I don't think it does.
What happens is that the plane picks up speed, but the conveyor spins faster and faster, so the wheels spin much faster than they would under normal conditions at that airspeed. The heat in the tires exceeds their design parameters and at least one of the tires blows. Then the plane nosedives into the conveyor or slides sideways off it. Or maybe ingests some fragments of the tire into and engine, which bursts into flames. Either way, people are going to die.
--- D
CHOWDAH RIDAH
2007 ZX-14 -92,000km
2006 BW'S -7,000km
2005 ZX636R -63,533km (stolen)
2004 SV650S -30,000km (sold)
2003 ZZR250 -15,000km (sold)
Current tire choice: Pirelli Angel
Last tire choice: Road Smart- 19,000 on last set (not the best though..)
CSC Certified Riding Instructor
the wheels really have little to do with it. They spin freely on the plane, does not matter what the ground does actually, it could even run double speed in the same direction as the plane, and other than the plane needing to pay attention to direction, it would not make it run faster, it would just spin the wheels faster, and they are not driving to the aircraft, just following along.. in other words, the plane would fly.Originally Posted by Duster929
Imagine you were riding a skateboard on a treadmill and keeping your position by holding onto a rope. You would be stationary. If someone pulled on the rope you would move forward. The computer controlling the speed would do a melt down because it couldn't ever get the speed to correct to zero because it is linked to the belt speed not the person pulling the rope. Either that or the belt / wheels would fry. If you were pulled fast enough and you had wings (Fat chance on this site) you would fly.
It never says “speed to zero”; it says “same as plane”. If your pal is pulling you forward at 10 kph, then the belt’s running at -10 kph. You’ll get pulled off the treadmill at 10 kph, with your wheels turning 20 kph.
The plan takes off, with its wheels tuning twice as fast as normal.
The plane flies. Everyone seems to be working off of one of two assumptions.Originally Posted by shil
1) the conveyor will travel at the speed that the wheels move.
or
2) the somehow magically the plane starts to howver because of thrust over the wings.
Here is the key as I see it. The "conveyor has a control system that tracks the plane speed and tunes the speed of the conveyer to be exactly the same"
So.. If the plane is moving, air is moving over the wings and generating lift, who cares how fast the conveyor moving as it tracks the flight speed.
If the plane is not moving because the conveyor is going in the opposite direction as the thrust., it still doesn't matter because in that case the conveyor is also not moving.
Remember the conveyor tracks the plane speed, not the wheel speed. The point is that in this example the plane IS moving, and therefore it WILL fly.
Now where's my free VFR as a prize?
I love it - even the aerospace engineers are all over this one...
Here's a good reference for a credible explanation:
http://www.straightdope.com/columns/060203.html
Jason
+1 i agree
Originally Posted by suprPHREAK
the plane takes off.....it leaves the wheels behind....cause they melted into the conveyor belt..
the wording of the riddle is rather cryptic, am i correct in thinking it means that the conveyor will adjust speed automatically to keep the position of the plane wrt to the ground next to the conveyor the same? think of a car on a dyno or something like that.
if that's the case, then i dont believe the plane will take off. lift has very little to do with thrust, it relies on the wing passing thru the air at speed. if the speed of the wing relative to the surrounding air is zero, then there is no lift. even the air being sucked into the jet engines will have little or no lift effect.
for the people who say it will fly, consider this. if the plane did take off, immediately after leaving the conveyor it would be some distance off the ground with zero air speed at full throttle, it might move a few feet forward before crashing back down onto the conveyor and once again, eveyrone dies a horrible horrible death.
Refactor the problem.
Imagine we take the convey belt and unravel it down the runway. The plane runs down the runway as per usual. Only there a tail wind exactly the same as the speed of the plane - so effectivly the plane is sitting in still air.Code:->- PLANE [_-_-_-] BELT
Code:@@@ WIND >> ->- PLANE -------------------------- BELT UNRAVELED
Could it fly in that? I'd say so.
What the wheels are up to isn't really material (especially once flying)
_/\_/\ . ÷ z z z Z ZZ
,,,-_-,,,
Bring everything you need and nothing you don't.
dammit... after reading superphreak's post a few times thinking he's an idiot... i realized it was me that was confused.
there is no "driving" connection between the plane and the wheels so long as the brakes arent on. so, no matter what the conveyor does, it is incapable of keeping the plane in the same spot, the wheels will be turning at very high speed but that has nothing to do with lift or thrust or blah blah blah..
fack.
no, it wouldnt fly. that's why planes take off into the wind.. it would end up in the westbound 401 collectors and kill everybody.Originally Posted by Insidious Dr.9
assuming your numbers are correct, you forgot one thing...Originally Posted by shinysideup
while the coefficient of static friction between rubber and dry concrete is about 1.0 (so assume a bit higher for asphalt), that is the coefficient of friction for a block of rubber. The wheels spin on their axles, they dont slide along the ground. so the coefficient of friction that you would need is between the wheels and the axle (which is mostly overcome with bearings, i would assume), not the wheels and the tarmac (that friction would be negligible)
by using your assumptions/numbers, the plane would NEVER be able to take off.
Mikey-D - Ottawa
"And yes, this is a site for people who ride bikes. But we don't ride bikes on this site. You can't ride a bike on the internet. On this site, we WRITE and READ about motorcycles." --Duster929
his logic is still wrong, but i initially thought the same thing.Originally Posted by Mikey-D
you cant slow down the plane by moving the conveyor backwards, it's simply impossible as there is no drive link between the plane and wheels.
the engines "push off" against the surrounding air, not the conveyor, the only affect the conveyor will have is making the wheels turn really really fast.
It won't fly. If I understand the question correctly the planes displacement is ZERO over the time the conveyors belt is turning. The only way a plane can lift off is air needs to pass over the wings to create lift. If the plane is stationary the wheels are turning and the conveyor belt is holding it in place then how the hell can there be lift created if no air is passing over the wings? ??? ? ? ??
THE PLANE WOULD HOWEVER FLY if there was a gigantic fan placed in front of it to create air speed over the plane to match the planes tire speed. Then theoretically it would take off once it hit the correct speed.
Without air passing over the planes wings it will not fly.
Here's a little demonstration. Go jump on your treadmill and pretend you are the plane, crank the thing up as high as it goes and run as fast as you can. You don't feel much against your face do you in terms of air speed. Now go outisde and run down the street as fast as possible and notice how the air hitting you. That is what the plane needs to fly.
Yup. I thought about this some more last night and realized it. My assumption was that the conveyor moves to counteract the plane's movement, and not at the opposite speed to the plane, in which case it takes off.Originally Posted by donut
Also, interesting to note that even if the conveyor were strong and fast enough to keep the plane still, it could still take off since the conveyor would be essentially acting like a fan due to air viscosity and boundary layer effects.
that demonstration is invalid... you are driven by your feet, sort of like wheels, a plane is not.Originally Posted by Martin
next time, put on some roller blades and get on the same treadmill with a rocket pack on your back.... no amount of treadmill speed will keep you from moving forward.
I'm not much of a scientist, but I believe you are correct. Because the engines on the wings are propelling the plane, not the wheels/tires the plane will progress down the runway regardless of what the wheels are doing... they have no drive.Originally Posted by donut
Support the fine arts, shoot a Rapper.
rewritten for clarity. This is also sent to an aerospace engineer, so I will let you know his answer:
Any aviator will tell you that it is not ground speed that is required for lift-off, but airspeed. As I am sure you all agree, it is air over the wings that works to create lift, and thus flight.
A plane derives this airspeed by moving forward as a reaction of the thrust of the engine (be it jet or propeller) pushing against the surrounding air.
The wheels of an aircraft are not like a car, in that they are not powered in any way. They have no effect on the aircraft's ability to accelerate. They are just dollies to, for arguments sake, eliminate friction with the ground.
So, since the wheels have effectively no friction with the ground, the conveyor can move as fast as it wants, but it will have no effect on the plane's ability to accelerate through the air.
The result of this, is if the plane is moving at +100kmh airspeed (since the engines act upon the air, not the ground), the conveyor is now moving at -100kmh groundspeed. Typical math says that this cancels each other out to equal 0 effective ground speed. However since the wheels are not part of the propulsion of the plane, and not causing the plane to go +100kmh, it will in fact add up to +200kmh ground speed, while still maintaining +100kmh airspeed. As long as the speed reaches the point where lift exceeds gravity, then the plane will fly.
Summary: due to wheels, there is zero friction with the ground (arguments sake, lets say they are mythical perfect zero friction bearings. Heck, we are talking about an airplane sized superfast conveyor after all). Because of this, the conveyor is presenting zero opposing force to the plane to slow down its acceleration.
CHOWDAH RIDAH
2006 BW'S -7,000km
Bookmarks
