A bit of valve noise is okay...
It could be a combo of valve/camchain noise.
The thing is, valves will loosen up or tighten up - depending on how they feel!
And you cannot hear the tight ones.
So even if there are no loose valve noises to hear, doesn't mean everything is alright.
This is why valve clearance should be inspected on a schedule, as per manufacturer's recommendation...
Regards
Bookmarks
