Why don't you just use your existing relay?
Hey, does anyone know which Electronic Flasher Relay is required for a 09 ZX6R?
I bought some LED rear plate signals off ebay and I'm not sure which "EFR" is required...
Would like to get something reasonable and cheap.
*~.Dan.~*
EX500 Streetfighter
Any brand will do just order/get the one that fit's your bike most local shops can order you the correct one.
And to answer the second question. The stock flasher relays are looking for more resistance in the line to trip the flasher portion of the relay. OEM signals use a standard incandescent bulb which is higher resistance. Once you switch to LED's the resistance is significantly lower which makes your signals flash too fast. If you were to change to all your signals you wouldn't see anything flash at all. Buy changing to an aftermarket LED flasher the build in resistance in the relay which slows the signals down to normal speed.
You May Wheelie Me Down The Road....But I'll Stuff Ya In That Corner Every Time.......
R.A.C.E. AM #16
S.O.A.R. Nov #16
www.puretrackdays.com
A big thanks to my sponsors: Yamaha Motor Canada Ltd., Brooklin Cycle Racing, Pure Trackdays Inc., Z1 Cycletech, Bickle Racing, Hindle Exhaust Systems, Armour Bodies, Accelerated Technologies., Don Butt Autobody, North American Decal.
Just bumped across this one.
http://www.customled.com/products/fl...sher_relay.htm
Looks promising.. Not bad since its $20 bucks.
Anyways, thanks guys!
Motovan has one fo $7.99, says it works with 1 - 4 bulbs..
OP, are the front signals LEDs as well?
What are you trying to do? accomplish?
'97 GSXR 600 SRAD - BLUE 19K
'00 CBR F4 - RED, 32k - Sold
'04 Kawasaki 636-Blue
'98 GMC Jimmy-294k-Sold
i have a integrated rear LED and flush mount leds up front, so how many flasher relays would i need to correct the flash rate?
I have exactly the same set up (Flushmount LED, Integrated Tailight LED). The stock relay doesn't process the signal correctly, hence you need electronic relay. I had used resistors but one of them burned out (they don't last long and create excessive heat, etc.)
I looked at the EFR's at Canadian Tire and Part Source and they have the generic EFR's for between $10-20. HOWEVER, they are NOT play and play for sportsbikes.
For the same money, I ordered a plug and play EFR from Custom Dynamics.
You just have to locate your flasher and the unplug the old one and replace it with the new one. On my '06 R6, it's under the tank - pain in the butt!
Good luck!
2006 Yamaha R6 Blue
Hyperpro RSC Steering Damper (Blue), Motovation Bar Ends and No-cut Frame Sliders, Swingarm Slider/Spools, Custom Dynamics Integrated LED Tail Light, Flush Mount Front and Rear Turn Signals, Yamaha Passenger Seat Cowl, Scorpio i-900 alarm, Boxer 5108 disk lock with alarm.
You could just add a resistor...
*~.Dan.~*
EX500 Streetfighter
that's cause most people try to get away with using severely undersized resistors that aren't even rated to be able to dissipate the heat from the load they will be subject to!
I agree that EFR are the way to go... but load resistors, if done right are not a problem.
Typical signal bulb is 26 watts.
Thinking you can dissipate 26 watts of heat with a 10 watt load resistor = imminent fail. Even if you factor in the approximate 50% duty cycle. - that resistor is gonna get HOT!
rant over - EFR = best solution.
ooh you got the trick one the standard one will also work just fine at only $14.95
http://www.customdynamics.com/trick_...rd_DOT_Flasher
R.A.C.E. AM #16
S.O.A.R. Nov #16
Bookmarks
