Thanks for the help. I'm not sure to be honest. This is my first time working on a car. I only came to that conclusion because ALL the plugs on the passenger bank looked out-of-the-box brand new and the other side looked rich. it runs smoothly revving all the way to redline though. so its probably not the issue.
I don't know what I'm doing. that's the problem. I've been just googling random misfire and checking stuff by other peoples suggestions.
The plug wires are brand new. I didn't check the resistance through them. I followed the firing diagram online and it seems to be correct.
I also tried finding out which cylinder is not firing by unplugging one ignition wire at a time.
each time i unplugged a pass. side plug, the engine would slow down. each time i unplugged a driver side plug, the engine wouldn't slow down.
The problem occurs when the rev drops below 1000 rpm. when I first start it, it is fine but when the choke comes off, it gets worst. The very worst is when its stopped in gear.
The idle speed is about 700-750 which i believe is correct. How would i check ignition timing? Also I had to replace the knock sensor because throwing a KS code.
I believe it uses a IAC. I'll check tomorrow. dirty injectors are also possible. How could I possibly have three injectors on the same bank dirty at the same time, when the other side is clean?
Here is a picture of the plugs btw: left is passenger bank, right is driver bank. the two others on each side look the same. I still can't wrap my head around how one side is so rich and one side is so clean. I know its a definite telltale to the problem as well but i don't know what it is.
I've been thinking about that. I don't have the tool to check fuel pressure. is there a simple test for this?
Bookmarks
