Originally Posted by
Brian P
NOOOOOooo don't do that. #1 it won't work, #2 you risk dissolving stuff that isn't meant to be submerged in gasoline, #3 you are asking for a fire.
If the engine will fire up on ether (starting fluid) then I just about guarantee that the issue is some combination of gasoline that has sat around for too long and has lost the most volatile fractions (which the engine relies on for cold starting), or when you put the carbs back together, something got buggered up with the settings of the idle mixture screws and idle speed adjuster and carb synchronization screws or the choke (enriching valve) mechanism or the float levels.
The floats have a drain screw on the bottom. Crack one of those open and see if fuel drains out. If it does, then the float bowls are full, and your carbs are (correctly) not accepting any more fuel because the float bowls are already full.
Make sure the idle mixture screws are set to factory specifications. Make sure the choke plungers on each carb are being correctly pulled open when you actuate the choke.
Sometimes if you can get an engine going on starting fluid, and keep squirting it in to keep the engine firing, it will eventually take over on whatever gasoline is being drawn in. If you can get it running like that, then you can check idle speed screw setting and so on.
Bookmarks
